Красный кабель - эт плоть от плоти, эт святое, должен каждый знать. Так чта не надо подъебэ… Скоро и цифровик такой будет. Эт вены аугоп-true АН. Такой же и в самом моём оте. И эт хорошо и отлично, щитаю!
Максим, какбэ предлагаю следить за словами!
OTO SE. Single-ended, EL 84 based, 10 watt integrated amp. Available with or without phono stage. The best amplifier value in the Audio Note line. Likely designed with the Audio Note K’s in mind, it makes a wonderful match with the 93dB J’s. The OTO is satisfyingly full, dynamic, and clear, sounding and wonderfully informative through the midrange. An excellent choice for a Rs 10L - 15L system with efficient speakers, a knock out competitor for the Manley Stingray and the Audiomat Arpege, among others. I am sure I have yet to hear all that it can do.
OTO SE Signature. The revered Signature version of the classic OTO SE was recently delivered to a discerning customer from Mumbai. “Ribbon internal connecting cable has been replaced with silver; Tantalum resistors and foil capacitors have been added in critical locations. Psvane tubes have been added. Most important, the M4 IE output transformers have been replaced with IHiB double c-core numbers, providing superior magnetic core material in a superior transformer topology for superior results.”
The OTO SE Sig is both more robust and smoother sounding than the standard OTO SE and to my ears obsoletes it. It is the more versatile and all purpose EL 84 integrated amp that owners of E speakers in particular have asked for. E’s and J’s are the OTO’s natural mates. We now have a fully worthy alternative to a Meishu for those who want the more direct, less atmospheric sound of EL84 tubes.
У меня дурацкий вопрос про регулировку громкости у ОТО.
На других усилителях под разные уровни записи разных дисков мне приходилось относительно заметно крутить ручку. На OTO обычное положение ручки 9 часов, на БСО 10. Но под разные уровни все время приходиться долями миллиметра прицеливаться.
Так у всех ? или я придираюсь ?
Manley в силу своей двухтактной души не играет тонкие материи. Он в основном рубит только. А ОТО рубит только там где требуется и все равно делает он это интереснее. Единственное преимущество Manley на 84-й лампе это умение раскачивать относительно сложную акустику. Обратная сторона таково вот преимущества 8!!! ламп EL84.
В UnicoSE было 140Вт на канал, там при 10-15% РГ уже ад в квартире начинался, там приходилось крутить по микронам, а в ОТО даже хорошо, плавно.
Я вообще громкость не трогаю, оставил часов на 10-11, кручу цифровой РГ источника (знаю что звук ухудшает, но удобно).
Скажите сколько по канонам ото греть надо. По ощущениям пара часов нужна чтобы звук стал мягкий. Или от ламп зависит?
Мой через 15-20 мин. субьективно в форме.
Наоборот, как то на выходных целый день слушал, с 8 до 22, заметил - вечером звук ухудшился. Стал слишком “жирным”.
Я как утром включаю, так и играет все одинаково волшебно и божественновеликолепно. Сразу, через 10 секунд после включения.
Играет волшебно но с прогревом уходит отстротца и больше бархата наворачивает имхо. Может от ламп зависит
у меня всё ровно, со временем, к ночи - ну…лучше или так же, стабильно работает.
10-11 часов нон-стоп
Тебя твои ощущения не подводят. Он действительно через примерно ± 2 часа начинает петь. На холодную он только начинает играть.
Непрогретый вообще не звучит, только подает
Аааа… так вы про новоделыыы…
Вчера послушали свой Line Signature и сравнили немного с ОТО Line обычный. Signature гараздее играет. Собраннее, чище, глубже и утонченнее. У Signature гараздо лучше контроль баса, у обычной версии бас вальяжно распущенный.
Вот что творят улучшенные выходные трансы. Сила
это какой?
SE Line не Signature.
новодел?
Да.
