25000 евро ;₽
Я его и на 6 тыщ за Павэйн не убедил))
Ах, да, в 25000 будет 10 000 нашей с ним болтовни)) Посчитал ведь))
Крис педалирует аналоговость звучания Metrum
##Встречайте Metrum Adagio
What more can you do after launching one of the best dacs available today?
We are aware that our current flagship Pavane is hard to beat but at least one idea was not realized yet. The idea of having a decent volume control to prevent a necessary pre-amplifier could improves performance dramatically. However, we also know that the way of introducing such device in the signal chain can also have a negative effect.
Experiments were made and as result the best sound was coming directly from our Transient™ modules. Even the digital approach did not convinced us but still one idea was not tried yet. Especially in case of R2R ladder dacs it is quite easy to change the output voltage of the dac by changing its reference voltage but to realize this, dedicated dac boards were designed to get the best regulation possible.
Like our Pavane, “forward correction” techniques are used to drive both mono dac boards. The result of this process is an extremely high linearity, right down to -140 dB, which gives the Adagio a realistic 24 bit dynamic range.
The Adagio is a step forwards as it omits a pre-amplifier. It is musical, honors the Non-oversampling principle and simultaneously incorporating the technological progress that has been made over the years.
Recommended retail price € 6950,00 The Dac preamplifier will be available end of June this year.
Интересно дойдут до 10 транзиентов на канал в итоге?
МАRANTZ))))
Нет.
Это штука сфокусирована на хорошем регуляторе звука
С помощью регулировки опорного напряжения. Решение с одной стороны на поверхности, а с другой - обеспечить стабильность и точность этого отрегулированного опорного напряжения - задача еще та!
Мода прошла.
“надо продавать,т к не хватает денег на напольники,либо меняю на Chord Mojo ,т к обзавёлся наушниками”
Тенденция.
“стандартный апгрейд” Ага, мы всё видим на фото. Интересно какой колхозинг ещё скрыт от глаз? Даже лундал куплен, но валяется без дела, греет душу.
Я заметил, что за редким исключением в виде истинных энтузиастов, апгрейженные Октавы почти у всех очень быстро ушли на вторичку и поменяли уже не одни руки, в то время как со стоковыми вариантами часто расставаться не спешат.
Просто люди веря байкам пытались выжать звук , и не выжали и продали… Другие купили надеясь на прорыв в сравнении со стоковым и тоже не обрели и продали, вот и крутятся они на вторичке. А кого сток устраивает, тот и слушает не парится, не продает.
Кто руководил этим “выжиманием звука”, советы по переделки шли от квалифицированных электронщиков?
Знаю я этик квалифицированных электронщиков, лохотронщиков. У них только осциллограф играет. Провода пофиг, разьемы пофиг,из чего транс пофиг. Окок делал твик одного, он с ушами хотя бы. Ну и электронщик вроде…
Сравнивать качественно твикнутый Октав со стоковым очень просто. Слышно сразу. Дешевый транс на входе и стоковый кондер сразу о себе заявляют (даже минуя остальные доработки) - это самое слабое место в ЦАПе. Тут нет нескольких мнений. У меня были все версии Октава - есть опыт. Сочинять “по фото” не нужно - нужно просто самому послушать в чем разница.
Пытаться самого себя убедить что стоковый лучше доработанного - ну каждый сам себя в чем-то убеждает. Личное дело каждого.
“If it measures good and sounds bad, — it is bad. If it sounds good and measures bad, — you’ve measured the wrong thing.” (*quoted from Daniel R. von Recklinghausen)
Для тех кто шпрехает ,парлит а не спикает.
" Если измерения по приборам хороши, а звук плох - это плохо. Если звук хорош , а измерения плохи - Вы просто неправильно меряете".
На фото кстати ,на операционном столе, стоит Минуэтт.
