номиналы
В катоды очевидно )))
Ух
Смотри личку. Вчера с челом говорили.
Now to news on the Black Gate replacements, basically work on developing the necessary carbonised paper is ongoing, so far the paper manufacturer has not been able to mass produce paper with the completely even distribution of the carbon particles that is necessary to be able to mass produce the Black Gate replacements, processes have improved over the past 4 – 5 years, but we are still some way from having solved this problem, the other problem relates to the manufacture, sadly not only had Rubycon decommissioned the older machines before we managed to get through to their technical department and start the process of restarting production, but Nippon Kodoshi, the original paper manufacturer, had also scrapped the machines that made the Black Gate separator paper, which is essentially what makes the Black Gate capacitor so very special, so we are essentially having to start from scratch and so far this has taken 6 years and from the discussions we had with Rubycon in January just gone it is going to take at least another year or perhaps two for the first Black Gate replacements to go into production, so don’t hold your breath!
Но!:
Forthcoming Audio Note™ Black Gate Replacements
The latest news is that we still have not solved the problem with the carbon impregnated paper, so whilst some progress has been made Rubycon are unable to mass produce the Black Gate replacement at the time of writing, sample production is possible and we have received samples of the WKz equivalent 100uF/500 volt and are in the process of running them in before listening to them seriously, all listening tests clearly show that, as expected, the samples are clearly of comparable quality to the original WKz Black Gate, although somewhat different tonality which is to be expected given that the paper is noy exactly the same as before.
Таким образом, вроде поехало столкача.
http://www.audionote.co.uk/comp/cap_electro.shtml
Просрали полимеры, т.е. графитовую бумагу
Пользуюсь случаем, ищу
BG FK 220x16B — 4 штуки
А я VK 22-350
так это старая инфа. @Slawa_Roschkow же писал, и в одной из тем приводил ссылки, что накатали там пока только высоковольтные, то что получилось.
Т.е. пока в бп, потом сделают и другие.
Пошло поветрие массовое. Берегите себя!
Слушал у Радослава уже прогретые БГ в катодах. Собственно сейчас уже для моего слуха идеально. Видимо приработались конды и пайка прогрелась(что не мало важно). Промежуточный вариант, неделя после установки БГ, мне вообще не зашёл. Сей4ас же прозрачно, быстро, разборчиво. То что надо.
Про настроение и степень готовности слушать и вкушать музыку не забывай.
Потом уже и на чёрные врата возмолиться можно.
Лучче купите старый ото, пятиручечный который.
отрицание гнев торг депрессия принятие BG
И на этом все!
Продолжу ряд…
…продажа сиги и покупка старой оты с пятью ручками.
Продавать сигу не надо.
Замена на BG вполне легкая промышленная операция для умелого мастера.
Старые кондеры сохраняются и легко можно поставить обртано
Скоро опрос делать “у кого в нотии BG завелся”
Адептов нужно знать в лицо.
Под впечатлением Дениса, описавшего свой опыт использования конденсатора BG между DAC и усилителем, соединил два полярных BG STD 470мкФ в неполярный и поставил его на вход своего усилителя SE 6Г7 + 300b. Вчера это сделал, сегодня уже понятно, что затянуло. Явно с потерями, но не отпускает. Интересно.
Записал звук, очень напомнило мою бывшую систему Audio Note. Жизнь по спирали…
А если по одному конденсатору поставить? В версии OTO Line именно так и стоят конды. Понятно, что не BG в базе.
