“With demand growing worldwide for high-fidelity music content and playback through mobile devices, Cirrus Logic (NASDAQ: CRUS) has introduced the low power CS43130 MasterHIFI digital-to-analog converter (DAC) with headphone amplifier” says the company’s press release. “The CS43130 DAC features a unique Non-Oversampling (NOS) emulation mode – believed by many audiophiles to contribute to the emotion of audio by providing a similar feeling as valve amplifiers or vinyl records – offering listeners a natural, euphonic sound missing from modern consumer products.” This new chip employs 512 individual DACs per channel in an analog/digital filter array to deliver Cirrus Logic’s top performing DAC. “With a THD + N of -108 dB and dynamic range of 130dB, the CS43130 has been designed from the ground up to focus on both superior hi-fi audio playback and ultra low-power consumption. The Cirrus Logic CS43130 consumes 23 milliWatts of power – four times less than other industry mobile hi-fi DACs – which helps to maximize battery life. The CS43130 supports up to 32-bit, 384kHz sample rate audio playback, ensuring the best possible listening experience.” There is support for Hi-Res Audio formats including Direct Stream Digital (DSD), DSD DoP (DSD over PCM), and up to DSD128. A proprietary DSD processor handles switching between DSD and PCM audio streams, while matching the analog audio output level. An NOS emulation mode offers “natural CD-player sound missing from modern-day DAC design” according to Cirrus Logic. Advanced hi-fi filters allow OEMs to tune their own signature sound.
кстати, может подскажите, есть смысл к нему докупать силовой кабель? это первый мой хайфай и я толком понять не могу это уже оно, или еще чето менять\исправлять
Поверьте, всё только начинается Совет простой - возьмите кабели на попробовать. Если услышите разницу в своей системе, купите, если не услышете - и не заморачивайтесь, используйте те, что есть.
А так Cooler надо здесь поосторожней с Gustard A20H
можно невзначай в носяру получить или под дых, еще и отпинать могут…толпой
держись за мной,я тут уже знаю кто что
К Михаилу кто тебе ответил по проводам присмотрись внимательней
Он вербует в Оппо и Денафрипс (это секты такие если не в курсе)
Будь осторожен, пару видосов посмотришь - и всё - я тебя потерял…а форум не заметит потери бойца, а такие как ты нам нужны!! будь внимателен!!!
С Кириллом тоже осторожней (кто лайк поставил Мише), там тоже не все так просто, про рок если его слушаешь с ним речь не заводи, скажу так: Густард рок не играет, это ты так всем говори (если кто спросит) и всё, а сам слушай, потихому, за закрытыми дверями…понял да?
Еще напоследок: кто не слушал Густард, те знают как он играет!!! с ними не спорь…
