Продам за 39 000 руб, без торга.
###вертушка Systemdek IIX — предтеча современных проигрывателей Audio Note.
10 кг, трехточечная подвеска шасси
Speeds: 33.33 and 45rpm (manual change)
Drive system: precision ground flat rubber belt
Platter: Glass 1.73kg, 10mm thick
Record mat: high density lambs wool
Speed drift: nil
Variation under load: 0.15%
Wow and flutter: 0.09% DIN
Rumble: 78/77 dB DIN weighted
Dimensions: 475 x 375 x 200mm
Weight: 10kg
http://www.vinylengine.com/library/systemdek/iix.shtml
###Вместе с редким тонармом Logic Datum Silver
Серебряная проводка, отобранные подшипники, вольфрамовый противовес, лучший хэдшел;
The Datum S is really quite rare and cost nearly double the II when new (it having Silver internal wiring, selected bearings, Tungsten counterweight, better headshell etc.) and it’s not easy to predict a current price though £300+ would seem reasonable for the spec offered and the sound quality potential.
http://www.vinylengine.com/library/logic/datum.shtml
