Старые «сонивские» должны, от сд, двд
Набрать на барахолке побольше и пробовать.
А… и от старого Самсунга еще, попытаться
Типа такого?
А смысл? Если можно купить любой Logitech Harmony и запрограммировать на любую железку (оригинального пульта при этом не нужно).
Проверить на совместимость до покупки можно здесь
Не , по моей ссылке сониевский пульт не удобен. Нет клавиши OPEN/CLOSE
У официального дистрибьютора, не?
https://audionote.su
Сегодня наткнулся на это весьма интересное описание ас:
Snell Type 1 in Walnut finish. Unique Peter Snell design that attempts to address room boundary issues in part by following Roy Allison’s pioneering work to minimize the upper-bass response dip that occurs when reflections from room boundaries arrive at the listener’s ear out of phase with the direct sound from the woofer. Removing this cancellation effect eliminates the most severe room-induced coloration.
The Type 1 rather radical design also tackles perhaps the most significant remaining interaction problem which is the middle and high frequency response ripples caused by interference between the direct sound from the speaker and its reflections off the floor. High Fidelity magazine spoke directly of this in their 1981 cover page featured review of the Type 1. “Because the paths of the reflections are normally much longer than the path of the direct sound, the reflected sound takes longer to reach the listener’s ear. If the delayed sound arrives in phase with the direct sound at a particular frequency, response at that frequency will be reinforced: if it arrives out of phase, the net output will be attenuated. The result is a series of peaks and dips in the frequency response. The pattern and severity of these irregularities very according to the height of the tweeter above the floor, the absorption characteristic of the flooring material, and so forth, but they are always present with a conventional speaker. Snell gets around this apparently intractable difficulty by putting both of the Type 1’s drivers–woofer and tweeter–as close to the floor as possible, thereby making the paths of the direct and reflected sound nearly identical. The remaining gap is closed by the addition of a ‘convergence baffle’-- a short ramp, hinged to the front of the speaker, that effectively extends the floor up to the drivers. Step says the slope of the baffle is calculated to make the paths of the direct and reflected sound converge (hence the name), so that they remain perfectly in phase over the entire frequency range for smooth, ripple-free response.”
The conclusion lauds the Type 1 for being a “cunning implementation of a fascinating idea” with “unusual attention to detail in both design and construction” and being “a good speaker, to boot”.
Лучше тут продолжить —🌑 Акустика за 8000 рублей разрывает все — экономим на Audio Note, покупаем Snell, JPW, Heybrook
Так и поступил, уже едет. Спасибо за совет.
А что с ним не так ? За 3000 евро как бы подарок
Похоже это только правый
Точно один
номер одинаковый на фото
Так в заглавии же объявления написано : " зроблен на украинском серебре".
Главное при копировании сайта появляется история с украинским серебром
а так на ебей все продаётся в Италии горячими средиземнорскими парнями
АС для центрального канала))) для удобной переноски связали SPx
Ага, как раз на Авито есть она AN-K L за 20 тыщ
Бояре! Помогите советом дилетанту!
Вот этот OTO интересует
https://www.avito.ru/moskva/audio_i_video/audio_note_oto_phono_se_signature_1764481558
Фото потрохов там есть, но оценить я не в состоянии(((
Кажется, это что-то из бара.
и квесты знакомые … похоже на те, которые за 260 продавали
нет (хотя…)
14й год - продавался не в Россию - если что имеем полное право чинить по “нормальному” ценнику ))
- есть повод поторговаться / а так на вид норм
