Здравствуйте! Посмотрите лог? Starting Live Log…
info: CoreCommandRouter::executeOnPlugin: wizard , getShowWizard
info: CoreCommandRouter::executeOnPlugin: system , getShowWizard
info: CoreCommandRouter::executeOnPlugin: system , getPrivacySettings
info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioStatus
info: CoreCommandRouter::executeOnPlugin: system , getSystemVersion
info: CoreCommandRouter::executeOnPlugin: system , getConfigParam
info: CALLMETHOD: system_controller system enableLiveLog true
info: CoreCommandRouter::executeOnPlugin: system , enableLiveLog
info: Launching a new LiveLog session
info: CoreCommandRouter::executeOnPlugin: my_volumio , detectVolumioHardware
usb 1-1.2: new high-speed USB device number 5 using dwc_otg
usb 1-1.2: New USB device found, idVendor=1058, idProduct=1042, bcdDevice=10.15
usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
usb 1-1.2: Product: Elements 1042
usb 1-1.2: Manufacturer: Western Digital
usb 1-1.2: SerialNumber: 5758383145333255544C3938
usb-storage 1-1.2:1.0: USB Mass Storage device detected
scsi host0: usb-storage 1-1.2:1.0
usbcore: registered new interface driver uas
scsi 0:0:0:0: Direct-Access WD Elements 1042 1015 PQ: 0 ANSI: 6
sd 0:0:0:0: [sda] Spinning up disk…
sd 0:0:0:0: Attached scsi generic sg0 type 0
…ready
sd 0:0:0:0: [sda] 976769024 512-byte logical blocks: (500 GB/466 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 47 00 10 08
sd 0:0:0:0: [sda] No Caching mode page found
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI disk
Device file /dev/sda inserted
Device file /dev/sda1 inserted
Trying to automount /dev/sda1…
Version 2014.2.15AR.2 integrated FUSE 28
Mounted /dev/sda1 (Read-Write, label “Western Digital 500Gb”, NTFS 3.1)
Cmdline options: rw,nodev,nosuid,noatime,uid=1000,gid=1000,dmask=0077,fmask=0177,dmask=0000,fmask=0000,uhelper=udisks
Mount options: rw,nodev,nosuid,uhelper=udisks,allow_other,nonempty,noatime,default_permissions,fsname=/dev/sda1,blkdev,blksize=4096
Global ownership and permissions enforced, configuration type 7
Successfully automounted /dev/sda1 at /media/Western Digital 500Gb_
Device file /dev/sda1 mounted at /media/Western Digital 500Gb_
Updating DB (#1) …
volume:100% repeat: off random: off single: off consume: off
info:
---------------------------- MPD announces state update: update
info: ControllerMpd::getState
info: sendMpdCommand status took 8 milliseconds
info: sendMpdCommand status took 4 milliseconds
info: Command Router : Notfying DB Updatetrue
info: ControllerMpd::pushState
info: CoreCommandRouter::servicePushState
info: CoreStateMachine::pushState
info: CorePlayQueue::getTrack 0
info: CoreCommandRouter::volumioPushState
info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
info: CoreStateMachine::syncState stateService stop
info: CoreStateMachine::syncState currentStatus stop
info: No code
info: ------------------------------ 102ms
info: CoreCommandRouter::Close All Modals sent
info: CoreCommandRouter::getUIConfigOnPlugin
info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sOptions
info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2sStatus
info: Getting Alsa Cards List without I2S DAC
info: CoreCommandRouter::executeOnPlugin: i2s_dacs , getI2SNumber
amixer: Mixer hw:2 load error: Remote I/O error
info: CoreCommandRouter::executeOnPlugin: mpd , getConfigParam
info: CoreCommandRouter::executeOnPlugin: mpd , getPlaybackMode
info: CoreCommandRouter::executeOnPlugin: system , getAdvancedSettingsStatus
info: Retrieving Cloud Streaming UI
info: Getting Tidal Cloud Configuration
info: Getting Qobuz Cloud Configuration
info: Asking plugin for UI Config
info: Getting Spotify Cloud Configuration
info: Saving Spotify Acccount
info: Got Tidal Cloud Configuration
info: Got it
info: Got it
error: Could not retrieve Spotify Config from plugin Spotify: no section found
error: Error retrieving Highresaudio conf: TypeError: Cannot read property ‘onSave’ of undefined
info: CoreCommandRouter::executeOnPlugin: albumart , getConfigParam
info: CoreCommandRouter::volumioGetBrowseSources
info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
info: CoreCommandRouter::executeOnPlugin: networkfs , listShares
Starting Cleanup of Temporary Directories…
Started Cleanup of Temporary Directories.
Прячте лог под спойлер.
Я не вижу здесь вообще никакой информации про сканирование папок. Либо хдд отвалился сразу, либо лог неактуальный.
Добрый день. Только начинаю юзать Volumio. А что Volumio не может принимать стрим без ресемпла? Пробовал из разных источников: и Бублик и Нейтрон. Все треки ресемплит в 48khz. Хотя из них же отправляю на ресивер и все без ресемпла в плоть до 24/192. И еще можно ли как-то в Volumio добавить свой m3u плейлист с радиостанциями? Спасибо
Ps забыл добавить,что малинка звук выводит через hdmi,но сомневаюсь,что это важно для приема стрима без ресемпла. Со Спотифай и с харда играет без ресемпла
Скорее всего, малина выводит так через hdmi.
Можно, но сначала его нужно конвертировать в удобоваримый плейлист для Volumio.
Сделать это можно например с помощью скрипта на python-e:
Странно,что она именно стрим по ДЛНА так выводит,а все остальное без ресемпла
@ Stellzz, вот пример плейлиста с кучей станций:
Его можно положить например в /data/playlist/
А пробовали mConnect?
Вот именно этот момент, подталкивает на мысль, что может быть все-таки дело в источнике. И бублик и нейтрон нагружены настройками, может где и потерялись нужные… mConnect на этот счёт наоборот лаконичен и по умолчанию стримит без ресемпла.
Это точно!
Вывод одной и той же композиции с TIdal в Volumio:
BubbleUPnP:
~$ cat /proc/asound/card*/pcmp/sub/hw_params
closed
access: MMAP_INTERLEAVED
format: S16_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 5513
buffer_size: 22050
mconnect:
closed
format: S24_3LE
subformat: STD
channels: 2
rate: 48000 (48000/1)
period_size: 6000
buffer_size: 24000
Причем в Бублике отключен ресемплинг на устройство.
А исходник какой?
Дело точно не в источнике. Ибо тут же отправляю эти же треки ,с этим же настройками с Бублика и Нейтрона по dlna на ав ресивер. И он мне показывает,что все приходит без ресемпла
И всё таки я бы попробовал.
Делов то на две минуты.
2.907 (02-07-2021)
Multiroom User Interface Improvements
TIDAL Connect Improvements
Fixed moving the first song in queue
А хост указан как звездочка * или вся подсеть 192.168.0.0/24 ? Попробуйте варианты.
посмотрите вот это. что то общее есть
https://volumio.github.io/docs/Good_to_Knows/Mounting_an_NFS_Share
Включения сервиса NFS недостаточно. Там нужно ещё шару настроить в меню пользователя. Вот тут:
https://www.dlink.ru/ru/faq/346/1740.html
начиная с пункта “Шаг 6” описан процесс.
Там же описано как правильно указывать путь к шаре на клиенте.
Большое спасибо за консультацию. Путь как папке NASа пишется неочевидным способом. Это стало видно в настройках Dlinka по инструкции что вы дали.
Работает
Это особенность NFS. Поэтому я и обратил внимание на этот момент.
Добрый день барменам и посетителям!!! Найдутся люди, которым нужна подписка в Volumio на Tidal и qoubuz. Можно оформить на 5 человек за 5к с копейками
